Cts-v t-56 + ls1 + ls7 clutch problems
I have a 2001 ls1 with a cts-v t56 on it, with a ls7 clutch and flywheel.I’m running a ls7 slave with tick performance shims and I have a 0.2 gap in clearance for the slave spacing and I have a upgraded tilton master cylinder. I have a problem where no matter what the clutch will not disengage, when I look in the bellhousing hole I can see the slave moving normally but it still won’t disengage, maybe a bad bleed ? I’ve bled it a lot of times… any ideas ?
