Options For Moving T56 F Shifter Forward?
Old 02-21-2022 | 02:32 PM
LS3JAG's Avatar
Default Options For Moving T56 F Shifter Forward?
I'm in the process of fitting the EROD LS3 and T56 Magnum F to my 76 Jag. Things are going fairly well but by using the Magnum F we traded one solution for another problem. The shifter position is too far to the rear by about 3-4 inches. The only solutions I seem to be able to find are those that move the shifter back rather than forward. Any ideas?
Old 03-03-2022 | 10:16 AM
dgcustomz's Avatar
Why not fab the shifter stick forward and up where you need it? kind of like this but forward...
Old 03-03-2022 | 10:30 AM
LS3JAG's Avatar
I've been corresponding with the folks at Threepedals about this. They can do the whole shifter assembly or they make a piece of billet aluminum that does much the same thing. They can go up to 4.5" on each which would put things where they need to be. I think one of these should work fine but wanted to see if anyone has any other options.
https://threepedals.com/products/shi...-lever-spacer/
https://threepedals.com/products/shi...throw-shifter/
Old 03-03-2022 | 10:34 PM
Onbusy's Avatar
The T56 Magnum might have the right shifter location for you. I'm curious what you find that works though, I plan on putting my T56 out of my '99 Camaro into a 1968 Camaro, and will run into a similar problem.
The following users liked this post:
wannafbody (03-05-2022)
Old 03-05-2022 | 10:27 AM
wannafbody's Avatar
I think your cheapest solution might be to use a MGW shifter with the clockable lever position. Might want to shoot MGW an email and ask. Does the transmission currently engage 2,4 and 6 without hitting that metal bar?
