Tilton ST-246 Clutch
I just got my Tilton clutch in, and wanted to share some pictures:
This is going in my 1999 Camaro, 408 with a Huron Speed V3 Turbo kit, and T56 Magnum F.
I was looking at the McLeod RST/RXT, the Monster S and SK Series, the Summit Racing Twin Disk, and this one. I ended up picking this one because I liked that the pressure plate wasn't stamped steel. I went with the Organic disks because it was still a sprung hub, and has a torque rating above the T56 Magnum's rating. The car will be mostly for cruising, but I plan to drive it back and forth to work once in a while, so I'm trying to keep that power streetable.
I've been eyeing that clutch. I like it for the same reasons you stated (pressure place isn't stamped and the hub is sprung). I have the Monster LT1-S and it performs but I do wish it had a sprung hub. One thing I do like more about the LT1-S is the 2-1/2" long spline engagement on the hub. Let us know how you like it once you put a few miles on it.
In my '66 Chevelle I replaced a McLeod RXT with a Tilton ST-246 between my LSA and Magnum. Surprisingly, the pedal effort is higher with the ST-246 but I really appreciate the damping from the sprung hub on the Tilton vs. the McLeod's solid hubs. It fit perfectly and looks higher quality than the RXT. After a couple of thousand miles, I really like it!
I have that clutch and throwout bearing on my TKX absolutely a great clutch. Zero chatter and it’s easy to slip into full engagement.
@Onbusy How are you liking this clutch so far? I'm considering it since Tick has a pretty sweet package deal for it and all the hydraulics.
Sounds like my problem, lol. I don't have the funds to buy everything I need all at once, and I don't have the time to do a ton of work either. I think I'm going to try the clutch kit anyway, given that it replaces all factory components with aftermarket pieces and I need to replace my hydraulics anyway. Thanks for the reply!
