T56 Magnum/ oem ac delco front plate/bellhousing
Old 04-22-2022, 10:35 AM
BEECHFRONT's Avatar
Default T56 Magnum/ oem ac delco front plate/bellhousing
I have a t56 mag and I am using the ctsv/zl1 oem bellhousing mounted to the t56 magnum, I dont plan on using the built in fluid pump, Can I just plug the pump hole, if so anyone know what the thread size is?
Thanks
Bill
Old 04-24-2022, 08:25 PM
AMP-D's Avatar
If you plug the pump output port, it will create issues. Loop it back to the return port and bypass any type of cooler.
Old 05-23-2022, 05:54 AM
BEECHFRONT's Avatar
Were is the return port located at on the t56 magnum?
Thanks
Bill
Quick Reply: T56 Magnum/ oem ac delco front plate/bellhousing
