T56 swap
Old 06-13-2022 | 05:25 PM
Barn Find CETA's Avatar
Default T56 swap
Quick question, I finally found a good shop around here to swap out my transmission. So, what will happen once the T56 is in and running with the automatic ECM? Will the car run? Will I be able to drive it home? ( 10 miles ) or will it be inoperable until I reprogram the computer? I just need to get it home. Or arrange a tow. Thanx.
Old 07-02-2022 | 07:53 PM
NZLS1's Avatar
you wont be able to use reverse with lock out still in, speed sensor plug should be the same, will throw codes but should still go.
Old 07-03-2022 | 10:37 AM
ok, everything is in and working really nicely. But, my traction control button doesn’t seem to do anything??!! No light comes on and nothing in the cluster when I press it. I didn’t read anything anywhere about wiring the traction control. So the fact that it’s not working anymore is expected after a t56 swap? Did I miss something? Or it’s not effected by the swap and it’s something else?? Thanx.
