How to install GM12570277 clutch master cylinder?
Car is 2000 z28 with LS1
How do I install GM12570277 clutch master cylinder?
It is pre bled, so do I just disconnect the original line at transmission, and then plug in new assembly? I dont need to bleed anything further?
Any trick to the quick disconnect at the transmission?
Please spare me the comments about how OEM clutch master cylinder is POS and how I should have bought aftermarket. This one lasted 24yr + my car is stock powertrain. I had friends who had issues with aftermarket so I am not interested in hearing it.
Thanks for any advice or tips you can give me
You should still bleed it all the way, the fluid does have a life cycle and there's always a chance of introducing a bubble into the system. The install should be straightforward, but it is an absolute PITA to install it when your engine is in the way. You won't have a lot of room to manuever. Get help to install the u-bolt nuts on the inside of the car. I don't know about the quick disconnect, it's been a year since I removed the one in my SS, but I don't recall it being very difficult.
Also, the vacuum bleed once everything is back together is key and takes some practice. Here is a good video for our cars:
You'll see all sorts of instructions on how to do this with screwdrivers, but it really messes up the quick disconnect. If you spend a few bucks to get the proper tool, you won't regret it! (They are really cheap.) Just search for 'T56 disconnect tool' and you'll see a bunch of designs: (I also recommend checking out youtube videos on this first!)
The following users liked this post:
01CamaroSSTx (02-23-2024)
