Tkx
Old Dec 16, 2024 | 08:47 PM
Rickydaman's Avatar
Default Tkx
I'm building a 92 obs chevy 2wd I'm wondering if I get the gm tkx transmission can I run the stock truck 4.8 lflywheel and luk clutch kit an stock gm throw out bearing from my local parts store? It would be behind a lm7 5.3 just trying to go the cheaper rout
Old Dec 18, 2024 | 08:57 PM
AMP-D's Avatar
You can use the flywheel and clutch but the slave cylinder assembly will not work.
Old Dec 18, 2024 | 09:54 PM
Rickydaman's Avatar
So the intenal slave for a 4.8 wouldn't work?, what would be idea set up for the tkx without killing the pocket?
Old Dec 21, 2024 | 10:17 PM
AMP-D's Avatar
No, you'd need to source an internal slave set up that rides on the factory bearing retainer. I think Tick Performance has some stuff available.
Old Jan 7, 2025 | 03:10 PM
rjacobsswa's Avatar
https://www.speedwaymotors.com/Chevy...ng,379207.html
Thats the setup that was recommended to me by a friend to run with my TKX behind LS swap in my track car. He's running it with an LS style clutch, said it works just fine. I havent built my car yet, still collecting parts.
