Slave shim alters pedal height?
Old Nov 24, 2024 | 03:46 PM
Gav's Avatar
Gav
Default Slave shim alters pedal height?
Hi,
am I over thinking this but...
The stock t56 slaves have a return spring so that when pedal is depressed the slave will only retract to tips of pressure plate fingers....correct?
So if you shim a slave it will make no difference to pedal height.....? I.e. the clutch fingers will always start moving from top of pedal height....assuming same slave diameter and master diameter and pedal pivot....
Regards
gav
Old Nov 24, 2024 | 03:49 PM
Rich-L79's Avatar
Shims have no effect on pedal height.
Old Nov 24, 2024 | 03:55 PM
Gav's Avatar
Gav
So why do loads people post shimming and referencing new pedal height?
I agree with you though
regards
gav
Old Nov 24, 2024 | 06:56 PM
the_merv's Avatar
Veteran: Air Force
Maybe referring to the point where the Slave starts moving into the Pressure Plate, as in a shim will make it closer to the top of the Pedal travel.
Old Nov 24, 2024 | 09:07 PM
Rich-L79's Avatar
The overall throw of the slave is the same whether it is shimmed or not. The trick is to shim the slave so the throw of the slave is where it needs to be to get the slave to fully release the clutch. Shimming will affect where in the throw of the pedal the clutch will release, but it doesn't change the physical height of the pedal.
Old Nov 25, 2024 | 02:02 AM
Gav's Avatar
Gav
I was really on about bite point rather than pedal height.
sorry I'm Welsh lol
think the penny has dropped anyway...
regards
gav
Old Nov 25, 2024 | 07:19 AM
Rich-L79's Avatar
sorry I'm Welsh lol
regards
gav
Well then yes, shimming will affect that.
Old Jan 9, 2025 | 03:44 PM
Phils95TA's Avatar
Hello, I am new to my 95 T/A, and it has a recently installed new clutch. However, and the previous owner pointed this out, the clutch engages like right off the floor, making take offs (especially with a 4.10 rear gear) VERY hard, especially if you have to get going quickly.
The clutch engages quickly, and doesn't slip, feels good, but I would like to have it engage higher up than just off the floor. What should I do or look for?
Thanks!
Old Jan 9, 2025 | 07:14 PM
the_merv's Avatar
Veteran: Air Force
Bleed it more or it may need a Shim on the Slave. Could have full travel with the Slave and at the bottom of the Pedal is just enough to dis-engage the Clutch, instead of being more to the top.
