Weird Noise
Whenever I press in the clutch I hear a whining/squealing sound winding down. I've checked and it's not the belts because up front you can't hear it, only from the drivers seat or outside car standing just behind the drivers's side front tire.
It's started doing it more and more and does it in 1st and 2nd gears now when you're just cruising and let off the gas with it in gear.
Any thoughts/suggestions??
Thanks.
Is there a bushing or bearing in the end of the crank shaft for the trany input shaft guys? I do not know.
Find out if it does it in any other gear at all.
With the car in 1st or 2nd and letting off the gas but still in gear it makes the noise.
Doesn't do it in nuetral.
19K and 2002 is still under warranty isn't it?
It sounds like something whining and slowing down as well.
Anyone else with ideas??
Thanks.
I just had my rear axle completely rebuilt. Had a seal go bad, leaked all lube out, and fried everything inside. It wind when I was driving when I first heard it, I took it directly to a shop. saved me in the long run. I know it's alot of money, but it could have locked up on the freeway and well.....let's say it could have gotten REAL ugly.
But I took care of it as soon as I heard it.
Anyway, replace clucth, and then Tranny or vice versa......Best I can really suggest....Might save you in the future. How? I dont know....But just might...LOL......Hope this helps.
Thanks.
