T56 Wont Go into 5th gear "HELP"
Just as the title says, everything is fine in every other gear but when I try to put it into 5th it just pops out of gear. Sometimes it will go in but I have to try to put it in very fast. This same problem happened to my brothers T56 but in 3rd and 4th gear. I think when he posted it people thought it was a`bent shift fork.
Any advice would be greatly appreciated. Also just put in Spec stg 3 clutch about 2k before tranny problems. No slicks or even drag radials and probably under 400 hp. Please help.
Originally Posted by jmd
diagnosis will require teardown but the fork pads may just be chewed up. Easy fix in a weekend.
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
Originally Posted by WS6dan
I am still under factory warranty at 19000 miles and have a extended warranty to 100k. I think that once they fix it I should still upgrade some of the internals to make sure nothing else happens.
But you do need to do the drill mod.
