new flywheel.
Originally Posted by formula383
For anyone here insterseted (tonyt123blue, SLP is clearancing new oem flywheels for $49.95, I just ordered one earlier today and that is what I will be using with my Spec 3.
I would also guess steel. You might should give them a call before long. They are clearanced right now, and when I ordered mine today the guy said they had 16 left.
Tony, are you going to go to the midnight race at Clay City on the 29th?
THis is Bobby, by the way.
If you've ever seen a flywheel explode, you wouldn't hesitate to drop the $$ on an SFI approved one. I'm rather fond of my legs, but maybe that's just me .
If you're not doing 6K dumps and 6K+ shifts, you'd probably be fine with the stocker. One other reason to match the clutch and flywheel would be to blame the manufacturer for making shitty parts if you have problems like so many others have. Good Luck.
