Tranny Locked Up In Neutral?
Old 10-25-2004 | 07:51 PM
Wease's Avatar
Question Tranny Locked Up In Neutral?
Driving my Formula to work the other morning, I'm just down the road from my house. I go to downshift/pull it out of third gear and I can barely get it out. Then I can barely get it in or out of any gear! I'm having lots of problems just moving the shifter around when it's in neutral. So I get it into 2nd and drive it back home and pull it into the garage. I'm pretty sure it's not the clutch, as it engages and disengages fine when I can get it into gear. The clutch it also brand new. Anyone heard of thise happening before? The 3rd and 4th gear synchros were about gone, but I wouldn't think they would cause this type of problem. I mean, I can hardly move the shifter when it's in neutral...
Old 10-25-2004 | 09:46 PM
jmd's Avatar
jmd
You broke keys or otherwise hammered the shift rail linkage. Needs disassembly and some parts replacement.
If you beat on the shifter without using a shifter with stops, that commonly happens with the 3/4 synchro as it will overtravel.
Don't forget the drill mod.
Old 10-25-2004 | 09:48 PM
Wease's Avatar
I'm guessing that's a rebuild then. Any idea how much that costs? I can get a used local rebuilt one for like $600 - $700. FYI, I am selling the car come Spring.
