clutchless tranny for street?
Hi, i am in the middle of a project with a BBC in a 98+ trans am, I wanna go with a clutchless tranny (g-force, liberty, etc.) I was wondering if anyone had any experience with these for street driving. thanks.
Originally Posted by critter
I've driven a proshifted T56 on the street. It wasn't bad once I got used to it, but the true clutchless (except for planetary/band trannys) tend to kick out of gear when you back off. You can't use compression braking with them.
I have a Liberty's and you could not drive it on the street period. It would be very annoying.
Matt
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You cannot one drive on the street( in traffic anyway) If by clutchless you mean the operator does not engage a clutch / the drive is RPM set(dump)then just think about how you are going to do that.I don't even see how this is fun let alone cool.
Im using Liberty's setup aswell. Ive recently learned when they say true clutchless, DONT SHIFT W/O. Atleast just tap it, touch it, lightly blow on it are something, because every time I try shifting w/o I wind up replace a shift shaft cotter key for some reason.
I think the Pro shifted tranny is plenty streetable, Its all a matter of opinion.
You will have to learn how to drive again in traffic. I only PRO SHIFTED 3rd and 4th, the ones I neaded the most. The good thing about that is if 3 and 4 give me problems I can just skip shift to 5th. Im not in 1&2 long enough to have them proshifted w/ 4.11 gears and a 93 t56 w/ lower ratios than most.
PS. Oh ya, transam427, If you go that route just make sure through normal driving keep your hand on the stick, it will pop out when you let off. In some cases I can be cruising in 3rd, let off the gas, tap it again and itll shift into 4th for me.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
I knew about the poppin out of gear thing, and no engine braking, but that wouldn't be that bad, if these are the only major issues with a clutchless tranny, I think I could work around that. Any others?
I don't think you have thought this out. Say your are rolling along the bouldevard in 3rd at 40 or so and the light ahead is red, so you lift the throttle and the trans kick into neurtal and the engine drops to idle as you start to brake. The light changes green. You are now going 30, in neutral, with the engine at idle, and no synchros to help you find a gear. So, which gear to you try for and how much do you blip the throttle so try to engage that gear without horrible grinding noises?
Can you not use the clutch in that situation?
In fact, it will probably grind and complain unless you shift fast and with conviction when upshifting. Even using the clutch, my proshifted transmission grinds a bit upshifting. I have to either shift real fast or real slow to avoid grinding. I usually push the clutch in, pull it into neutral, let the clutch out, count to three, push the clutch in, and slide it in gear. That works nice and is quiet when upshifting. Down shifting? I generally don't do that unless I am stopped.
Now, if you got a panetary/band transmission like a lenco, you don't have any of this hassle. They are nothing but a manually controlled automatic. Instead of having a hydraulic cylinder in the trans clamp a band around a drum to get the next gear, you pull a lever.
Originally Posted by SidewayzOZ
Dont those things whine like crazy though? That alone would make me not want to street it.
So could you use a lenco clutchless on the street?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Sure. A Lenco would be a lot better to drive on the stree than the other kind of tranny, like Liberty, Richmod, G-Force, etc. In fact, you often see Lencos in the Pro Street cars in the car rags but seldom one of the other kind. Just look for the forest of levers when you look at the pictures ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
