missing a shift..
Old Jan 9, 2005 | 07:51 PM
TTU98SS's Avatar
Default missing a shift..
how bad is it if i was basically hauling @$$ and missed a gear, causing it to redline? M6 newb my LT1 was an auto... thanks and sorry if its a stupid question. - darren
Old Jan 9, 2005 | 07:56 PM
Turo's Avatar
do you mean you grinded a gear, or you went into the wrong one? you could bend a pushrod if you go into the wrong one and it redlines hard. as long as everyhting is working ok and you dont hear any strange noises, you should be ok. just try not to do it again, the tranny will thank you
Old Jan 9, 2005 | 08:48 PM
SlowTA's Avatar
you would of noticed by now if somehing was messed up so this time you are good
Old Jan 9, 2005 | 10:12 PM
TTU98SS's Avatar
no actually it was the 1-2 shift and my hand slipped off the shifter so it basically just redlined in neutral and bounced off the rev limiter a few times thanks - darren
Old Jan 9, 2005 | 11:08 PM
SlowTA's Avatar
oh thats not AS bad if its just in neutral
Old Jan 10, 2005 | 10:06 AM
calhoon's Avatar
Not a stupid question and not something that every manual driver has not doene( if they tell the trurth) Hitting the limiter in N is not damaging. Missing a shift = getting1st instead of 3rd/ 3rd instead of 5th ect = and actually letting out the clutch can be devastating to an engine. Not letting out the cluych can still be bad if the speed of the clutch gets too high. Best to not doe any of these things.
Old Jan 13, 2005 | 09:36 PM
tcarswell's Avatar
You will be fine tapping the rev limiter a few times in neutral. A mechanical overrev however .... 3rd to second on accident will usually throw a rod.
Old Jan 13, 2005 | 09:52 PM
1ScrudeDude's Avatar
I don't normally consider myself a lucky person, but this time I dodged one:
https://ls1tech.com/forums/manual-transmission/249029-t56-tranny-pretty-damn-tough.html
