pulled trans last night
Old 01-26-2005, 07:44 AM
m6z
m6z's Avatar
Default pulled trans last night
I pulled the 6 speed out of my z28 last night. It took about 4 hours. How long did it take the rest of u to get one out? The dowl pins in the motor were seized to the bell housing, is this normal?
Any way here is the list of upgrades, what do u think?
RAM POWERGRIP 600HP/TQ CLUTCH
FIDANZA ALUMINUM FLYWHEEL
STEEL SHIFT FORK
G-FORCE BILLET SLIDER KEYS(SET OF 3)
THE GEAR BOX BASIC OVERHAUL KIT
& WHAT EVER LOOKS LIKE IT NEEDS REPLACING(SHOULD FIND OUT TONIGHT)
Old 01-26-2005, 09:27 AM
Kurtomac's Avatar
just pulling the trans....maybe an hour..... trans clutch and bellhousing prob 1.5 hours, the dowels usually get stuck like that in the bellhousing, i just keep beating till she comes off
Old 01-26-2005, 09:50 AM
LOnSLO's Avatar
You'll have it down to less than 30 minutes after a few times. That list of parts looks good. Scotchbrite your dowels and put some anti-seize on them before you reinstall the bellhousing.
Old 01-26-2005, 12:56 PM
m6z
m6z's Avatar
ya, it was the trans, clutch, and bellhousing
Old 01-27-2005, 08:55 PM
MrEddie's Avatar
Did you have access to a lift? I'm curious if this is too difficult with jack stands/rhino ramps. Trying to move around a 100+ lb tranny on your back doesn't sound very easy....
Old 01-28-2005, 07:58 AM
LOnSLO's Avatar
I can do it faster on jack stands, but a lift and tranny jack are nicer.
Old 01-28-2005, 08:25 AM
Stryker's Avatar
30 minutes is about right..
Old 01-28-2005, 09:31 AM
seal's Avatar
my buddy had his auto taken out in like 15 mins :o
Old 01-29-2005, 02:14 AM
That's what she said...
TheBlurLS1's Avatar
i put my regular jack under the tranny with the handle pointing at the rear end, i stabilized the trans on the jack, then had my uncle ease it down and out from under the car. we put it back in the same way, no problem!
Old 01-29-2005, 05:09 AM
991LE's Avatar
I am not going to bench press my tranny into my car again. I rented a tranny jack last time, but when I got ready to use the dang thing it wouldn't work with a load on it.
I am going to get an adapter for my shop jack
Harbor Freight tranny jack adapter
Quick Reply: pulled trans last night
