Need Help With T56
Spend a few bucks on a miti vac and it will make life alot easier.
You will need to bleed the hydraulics a few times to get them right.
With the Mity Vac you just put the hose into the hole in the bottom of the MC resevoir and pump up the vacuum. It will suck the air out.
I have also found that when running DOT3 fluid it is neccasary to bleed periodically due to the heat that the hydraulics are exposed to.
Since I changed over to DOT 5 I have not had this problem.
Brad
