New code problem
Old Feb 19, 2005 | 03:42 PM
my01camaroz28's Avatar
Default New code problem
I just finished replacing the flywheel, clutch, cylinders, and bleeding the system. I took the car out for a spin and have three new codes that just popped up.
P0102 - mass airflow circuit failure
P0801 - Reverse inhibit control circuit malfunction
P0803 - 1-4 skip shift control circuit
What do all these mean and what is the relationship between them and a clutch replacement?
Old Feb 22, 2005 | 11:36 PM
KrazyDan's Avatar
gearchatter.com
Old Feb 22, 2005 | 11:45 PM
2K2WS6TA's Avatar
My guess
PO102, Your Maf isn't reading the airflow (replace MAF, check connections and wires) nothing to do with the clutch install, just an unhappy coincidence
PO801, you have a solenoid that prevents you from putting it in reverse above a certain speed (5mph IIRC) that isn't functioning.
Make sure the connection is good, and you haven't switched the connector with the CAGS
PO803 CAGS solenoid isn't functioning, again check your connection, and make sure you haven't swithched connectors with the reverse lockout
I'm betting you simply switched the reverse lockout and the CAGS connectors when you finished the trans install (easy to do BTW)
Old Feb 23, 2005 | 09:03 AM
Dustin Butts's Avatar
Check your connections under the car. One or more of the plugs on the trans is unplugged or you've burned a wire on an exhaust pipe. All these codes are on the same circuit.
