power shifting
Old Mar 14, 2005 | 11:24 PM
ace68's Avatar
Default power shifting
I want to do some power shifting this year at the track. What will I need to do to my M6 to handel powershifting at the track?
Old Mar 14, 2005 | 11:37 PM
12stones's Avatar
You'd have to have a beefed up unit no doubt. personally the gains of powershifting just arn't worth the cost in the long run.
Old Mar 15, 2005 | 01:30 AM
ace68's Avatar
I'm not looking for the long run just the 11sec run.
Old Mar 15, 2005 | 11:51 AM
Steve Burger's Avatar
LS1TECH Sponsor
I would look at other HP, traction, and weight mods first. Power shifting will not net you .7.
Old Mar 15, 2005 | 12:41 PM
ace68's Avatar
I got for this year:
MT DR's on 16" rims
Skinnies
4/10's that have been cryo treated
TA cover
welded tubes
Air bag
Dyna bat
Lightweight flywheel
EWP
short belt
and this stuff
.7 I'll take it tell me what I need to do to beef up the t-56 so I can powershift and run 11.8
Old Mar 15, 2005 | 01:00 PM
LT1-Z28's Avatar
Beefing up the t-56... i know that our shift forks are crap and prone to bending... so you can upgrade to steel ones... other than that i am curious to hear what toehr stuff one can do... I guess theres also a good clutch...
Old Mar 15, 2005 | 01:07 PM
LS1TECH Sponsor
Upgrade the shift forks, syncros, and slider keys. Get a good clutch and shifter as well. Look at the D&D performance web site for more information.
http://www.ddperformance.com/
Old Mar 15, 2005 | 04:45 PM
smokeum99ta's Avatar
I got my tranny rebuilt and got a new input shaft($300) cause of damage from the clutch splines, carbon fiber blocker rings , steel fork , all new bearings and sliders keys.All this work costed me $1100 and they claimed it would handle everything I put to it. As for power shifting I've never had any luck doing that and putting down better times. Maybe I'm no good at it and you'll have better luck.
Old Mar 15, 2005 | 09:25 PM
glennster's Avatar
yellow.........very yellow.I would look for gains somewhere else,its not worth it and you will miss a gear sometime.That suspensions gonna be noisey.
Old Mar 15, 2005 | 11:51 PM
ThirdGenLS1's Avatar
His suspension shouldnt be to noisy i have the poly/spherical ends on my suspension from spohn and its not much louder then stock.
