Double shifting?
HMM most of those three pages are about m6 vs a4 and the usual stuff that goes along with that. Wasnt trying to get that started, think you misunderstood me. Just saying that I cant see why you would do that but then again I havent ever done autocrossing.
Originally Posted by B T
You should try driving around in a M6 car ( or just a manual trans ) and not using the clutch at all after first gear by rev matching the rpm for the gear up or down shift.
Try getting a manual car to move without using the clutch ( gotta use the starter to get it to roll and fire the engine then it's all fun from there.
No problem, I didn't want to go down that road either, I just thought I would include the link if you wanted to see the "whole context" behind the cliff notes.
All I can tell you is, when "I" go into or try and make a hard tight corner and have to slow down, I don't want to just be using the brakes to make the corner with the engine "loose" in the gear I don't need it to be in to help me exit the corner if down shifting (with the CPU ) might cause the car to be a little unstable instead of smooth. like a stick shift is.
Originally Posted by DamanZ28
But, does regular downshifting really hurt the trani that much?
Double clutching, is a counter-intuitive term. It is shifting WITHOUT use of the clutch. If the RPMs are at the right speed, you can use it on an upshift or a downshift. It will simply slide into gear with no resistance. But the RPM has to match the wheel speed of the gear you are wanting to go into.
