Burn out?
Old Apr 2, 2005 | 09:19 PM
rookie00SS's Avatar
Default Burn out?
This is going to sound real dumb, but Im new to a stick and was wanting to know how to do a burn out with a standard?
Old Apr 2, 2005 | 09:35 PM
More power!'s Avatar
Depends on whether you want to stand still or not...
Just take off in first and floor it = tires will spin.
OR
Bring the rpms up to 3000 or so and dump the clutch in first gear = lots of tire spin.
OR
Same as above but in second gear to REALLY get some smoke going.
To do any of this while staying in place requires a quick left foot to get off the clutch and on the brakes enough to stop the car rolling but not enough to stop the rear tires from spinning.
Second gear = lots of smoke!
Old Apr 2, 2005 | 09:52 PM
rookie00SS's Avatar
OR
OR
Standing still, like when Im at the strip and do my burn out, before staging.
Old Apr 2, 2005 | 10:19 PM
SStheBest's Avatar
yes.....but u actually dont need to stand on ur brakes jsut enough to keep it from movin
Old Apr 2, 2005 | 10:49 PM
02SOMWS6's Avatar
get yourself a line lock
Old Oct 27, 2007 | 05:42 PM
fortmyerspolice's Avatar
Sorry for reviving an old thread but won't the ABS engage from a stand still? And dumping the clutch at 3000 sounds bad for the 10 bolt.
Old Oct 27, 2007 | 06:05 PM
BLK02TA's Avatar
Nope it will work fine.
Old Oct 27, 2007 | 08:31 PM
LS14U2NV's Avatar
yeah don't hold to much break down, i did that other night my first time trying to do a burnout i got it going pretty good but i had to much break and i killed it..... pretty embarrassing .
Old Oct 27, 2007 | 09:11 PM
liquidmetal's Avatar
You also want to make sure you do not redline.Your car might turn off if you redline or it will just bounce the tack
Old Oct 27, 2007 | 10:59 PM
is there an abs light on the dash?
