Car would'nt shift into gear
I was at the track & did my burnout before staging. Everything felt fine so I roll up to the line & I could not shift the car into gear. The pedal felt normal. So I had it towed home & then I tried it again & was I was able to get it into gear. It's a newer exedy clutch with new master cylinder & slave cylinder. Any ideas on what could be wrong.
Your slave isn't pushing in enough to release the clutch. Try to re-bleed the system or upgrade your slave. The same type of thing happen to me- clutch wouldnt release during speed shifts. I had to shim my slave to get the extra reach.It will go away once the clutch is broke in but for now rebleed the slave or upgrade the system to a 02 set up or get a mc unit
