CARTEK OR RAM
Thanks
Abe
Mongoose, I would STRONGLY suggest you purchase the Cartek or an equivilant clutch for your application (I haven't heard enough about the Ram clutch to have an opinion on it. I do believe the McCloud has had good results, though. I think there's a McCloud in MickeyC5's 10-sec, stick Z28). If you purchase the Z06, it may only last you a half a season if you're lucky with your power. And, that I've seen from experience.
[ December 11, 2001: Message edited by: NYNJRacer ]</p>
Are you the same guy who was auctioning a heads/cam engine on Ebay under the name NJracin or something like that.
<strong>I have the Cartek, I love it. Not pushing much power though. Apparently the Cartek is a little more streetable, where as the RAM is a more of an "on - off" type clutch.</strong><hr></blockquote>
Only the clutch Harlan is using is on/off. He has a metallic friction material. you can get organic materials with their higher clamping force PP. Plus it's like $300.
Abe
That sounds like the Spec clutch PP. The Cartek PP does not have holes in it and the disk friction material is metallic, not carbon or kevlar.
Mark
<strong>The Cartek clutch is VERY streetable, with no chatter.
Abe</strong><hr></blockquote>
I have heard of a couple people on this board with a Cartek and theirs chatters.
BTW, I'm going with the RAM because it's like 1/2 the price. <img src="images/icons/shocked.gif" border="0">
[ December 11, 2001: Message edited by: J'sRamAir ]</p>
Abe
11.3/124 mph spraying out of the hole on ET streets. 02 Z06 clutch, still living to this day on a heads/cam/intake/nitrous car. <img src="gr_tounge.gif" border="0">
I have compared the Cartek PP, and it looks the exact same at the GM fullsize truck disk. I could be wrong, but it looks like the EXACT same design.
Abe
As Abe said, the Cartek pressure plate is NOT a GM product. It is manufactured by Borg & Beck and their name is even stamped on it. Looks more like a heavy industrial truck application.
Tony
