Clutch Pedal sticking Please Help!
Well we just go through swaping motors and we put in a ZO6 clutch and PP. When we put the everything in the clutch felt fine. Id push it down and it felt normal. So now we try to bleed the clutch and now the clutch stays on the floor when we push it. We kept bleeding it and it will not come back up. We tried changing the spring on the clutch and it now pops back up but it feels real light like the hydraulics are not giving any resistance. Also it will not go in gear. Could some one tell me the procedure of bleeding the clutch maybe we are doing it worng. Or if you guys know what the problem is please help me i want to get my car running. Been without her for 2 months now <img src="gr_sad.gif" border="0">
Well the clutch was working fine until we tried to bleed it. Maybe we are not bleeding it right or something?
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
[quote]Originally posted by awax223:
<strong>Well the clutch was working fine until we tried to bleed it. Maybe we are not bleeding it right or something?</strong><hr></blockquote>
What procedure are you using to bleed the clutch?
