Clutch for FI!!!!
Old Apr 29, 2005 | 04:48 PM
HellRaiser's Avatar
Default Clutch for FI!!!!
K guys I need to get a clutch and was thinking spec 4 or 5 but I hear so many stories about spec clutch's. Will they hold the power and last? Also do I need a new flywheel or can I just get the stock resurfaced? I don't wanna give my left nut for a clutch setup!
Old Apr 29, 2005 | 07:44 PM
Unusual T/A's Avatar
Either do it right or don't do it at all. YOu are going to pay either way. Do the spec 3 or 4. Yes if you can resurface the flywheel, if you can't buy a new one. DOn't be a cheap ***.
Old Apr 29, 2005 | 08:13 PM
2000 Tran Zam's Avatar
how much power do u need to hold? ive got a slightly used spec 3 used for 2 months id let go for 275 shipped. does not include flywheel as i resurfaced mine.
Old Apr 29, 2005 | 08:23 PM
HellRaiser's Avatar
I said I was thinking about getting a spec 4 or 5 and wanted to know if I really needed a new flywheel or if I could just resurface the stock one. So where does that make me a cheap ***? All I wanted to know is if it would hold the power? What I won't do is spend 1,500 to 2,000 for a clutch thats where the left nut comes in!
Old Apr 29, 2005 | 08:41 PM
StoleIt's Avatar
NKAWTG...N
dont have much experience with the 4 or 5, but for silverghost the spec 3i has held up like a champ. He's made a ton of 11 second passes on it drives it on the street regularily.
Edit: And definitly either resurface the flywheel or get a billet one.
Old Apr 30, 2005 | 07:00 AM
JMBLOWNWS6's Avatar
I use the 3F. It is the one that replaced the 3I and it is a full disk. Basicly a stage 4 that has great street manners. Better than the stage 3 carbon I use to have.
Old Apr 30, 2005 | 08:49 AM
smokinHawk's Avatar
id get the 4i.
its good enough for mightymouse
Old Apr 30, 2005 | 09:15 AM
Wyckedcamaro's Avatar
a friend of mine has the new cartek clutch and has done a ton of mid to high 10 second passes.
the clutch is built for strokers, turbos, superchargers, nitrous, heads and cam with nitrous.
can handle gobs of power.
he has 505 horse to the wheels and doesnt skip a beat.
I am in the process of buying his entire setup and transferring from auto to his manual
Cant wait.
plus I have nitrous 150 wet shot so I am gonna be the guinne pig for the juice on a clutch from cartek it looks like lol
Old Apr 30, 2005 | 11:40 AM
HellRaiser's Avatar
Originally Posted by smokinHawk
id get the 4i.
Is the 4i the same as the TRN-Spec f upgrade? http://speed-eng.com/store/index.php?cPath=22_61_674
Old Apr 30, 2005 | 01:19 PM
JMBLOWNWS6's Avatar
As I posted before. F replaced I
Old Apr 30, 2005 | 01:35 PM
HellRaiser's Avatar
Thanks....
