Cartek adjustment?
Cartek adjustment?
I wondered if you guys might be able to help me to see if I need to adjust my M/C (which way is what, anyway?). I have the stock shifter in my car - but I made my own short stick the other day. Ever since then my I cannot seem to make my car shift FAST. It seems as though it will only shift at a certain speed. I occasionally grind the gears too (almost never happened before). Perhaps the engagement is too close to the floor? One of my fbody friends drove it ang agreed... but a mustang budy drove my car, and powershifted every gear with easy, excaming he loved the shifter. I am really confused, I don't know what to do or where to start. I thought it might be the POS shifter too. Perhaps the thing to do is call Cartek, but I want you opinions too!
Re: Cartek adjustment?
I've only had my cartek in for a couple weeks, but mine grinds once in a while, which means the disc isn't completly disingaging the flywheel. What we need to do is adjust the master cylinder, turn the adjusting nut in the direction that lengthens the rod.
