Seal leak and a question
12523293 - Seal, Reverse Lockout Solenoid (O Ring)
12523301 - Seal, Reverse Lockout (O Ring)
10117848 - Seal, Main Shaft (Double Lip) or
12530278 - Seal, Main Shaft (Triple Lip)
12523293 - Seal, Skip Shift Solenoid (O Ring)
while your in the trans,check all the teeth on all the syncros and blocker rings with a magnifing glass. look for any burrs ect. teeth should be kind of sharp. rounded corners are not good. and you should install a new steel shift fork...3-4 while your in there. when putting the unit back together,be sure to use a good sealer..g.m. sells it. g.m.s. its called. when cleaning the surfaces,make damm sure you use brake clean! any small amount of grease and it will leak.
good luck
Are there any other gaskets i need to order after i remove the front adapter?
Thanks!
