Clutch master cylinder question? Please help!!!
I know this probably is not the place to post this, but I am desparate.. I need to find someone that has the 2001-2002 clutch master cylinder in stock. Can anyone help me? My car is stranded.
Thanks,
Kevin
Thanks,
Kevin
LS1Tech Co-Founder
Re: Clutch master cylinder question? Please help!!!
Why not replace it with a good adjustable unit from Cartek or Mcleod? Most of our sponsors carry Mcleod stuff, and you can reach Cartek at 908-317-4496
And you are correct, this is the wrong section. Moving to drivetrain section.
Tony
Tony
Go w/ the adjustable from Cartek. If you buy the McLeod, you'll have to bleed the clutch w/ a hand pump which might be a big pain. Instead go w/ the Cartek adj. master cylinder (pic below) as it is a complete self contained unit w/ fluid.
I just bought a McLeod from Thunder Racing. They had the best price at $200, by far. I'm sure the Cartek unit is OK, but the McLeod is an all steel unit, much stouter than the plastic OE/Cartek units. I haven't finished the install yet, but, all the feedback and research I did indicate the McLeod is a dynamite unit.
[quote]Originally posted by gm_jim:
<strong>I just bought a McLeod from Thunder Racing. They had the best price at $200, by far. I'm sure the Cartek unit is OK, but the McLeod is an all steel unit, much stouter than the plastic OE/Cartek units. I haven't finished the install yet, but, all the feedback and research I did indicate the McLeod is a dynamite unit.</strong><hr></blockquote>
I heard the same thing I'm waiting to install mine too as sone as I pickup a new clutch and the spring weather get's here <img src="gr_sad.gif" border="0">
