Where can you get a flywheel resurfaced ?
I have the old one I just took out when I did the 2002 ls6 clutch install. I want to get it resurfaced for the next clutch install I will need to do. Where can this be done ?
[quote]Originally posted by MechMan:
<strong>Lake part auto Machine shop.
Right off of Northlake and A1A.</strong><hr></blockquote>
Thanks Brian.. how much did they charge ?
Look under "Clutch" in the Yellow Pages (or under Automotive Machine Shops / Engine rebuilding). You should see a local machine shop that advertises flywheel grinding. I had it done last week for $30.
-Andrew
-Andrew
