m6, stock clutch, daily drivers inside please....
I was just wondering how long do your STOCK clutches last???? Of course other things come into play such as amount of horsepower, traction, etc....
I have had my car for less than 2 years and I am about to put my third clutch in it..... I dynoed my car and it puts out a wopping 300/330 to the wheels
The ONLY reason i keep putting the stock replacement clutch in it is b/c i got LIFETIME WARRANTY on it.... so how long do your clutches last...
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Gruffy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_gruffy.gif)
Originally Posted by stang killer
I think its time you do what I did and get a stage 4 with AL flywheel. If I ever see you out at one of the meets ill give you a ride. ![Gruffy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_gruffy.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
SSU, come over and relax
im at 82k and i dont think the clutch has been changed. is there a way to tell without taking out the tranny? also ive never had to replace one, how do i know if it is slipping?
Originally Posted by RICEBURNER
would a bad clutch also create a grinding noise when shifting hard into 1st, 2nd, and 3rd?...kinda new to the f-body....any help is great!
mine just started slippin rather noticeably the other day, and im wondering how long its been like this. so im lookin in to a replacement. as a DD i was thinking a spec stage 3. any comments/suggestions?
My car has 32k on it, original clutch as far as I know. I got the car with 25k on it in Jan. It was bone stock and I have the mods in sig. This past sat I went to the track and I didn't slip it or drop it, I did the "controlled clutch dump" I have posted about before. 1st pass I pulled a 1.939 60ft on the same street tires as always. Somewhere during the run it slipped some. Next pass I 60ft 1.935, and VERY soon after it started slipping BAD. Pretty much all through the rest of 1st, and when I hit 2nd it was awful. I let out and I have it on video....smoke rolling out from under the car like it was on fire
That was it for me for the nite. I parked it and didn't drive it for 2.5 hrs, and that was for the 60ish mile drive home. Almost home I am in 1st, rev it out to 4k and shift pretty quick to 2nd, and it barks em. So the next test I gave it was a 20mph roll race with a buddy. I hit the gas and the car spins a little, I shift to 2nd and it chirps loud and hard.....so it's ok I guess. I'm thinking that it will be sufficent for the street but the track is too sticky for it to hold. So when money allows I will be upgrading my whole setup, hydraulics and all.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
having similar problems just like you BRIANCWS6.... when i get on it hard it will start to slip, after if gets hot or what not.... but once it cools down seems good to go. I've already got the new clutch ready to go, just waiting for this one to give out completely, so i can swap this one in....
stock clutch with 40,000 and lots and lots of hard launches at the track and a few donuts. Still holding strong and feels like it's still grabing where it was when i first got it.
