Is This The Right Trans Mount?
Energy Suspension
Prothane
Are these just standard GM trans mounts?
When using one of these 2 do you lose the failsafe locking design of the factory mount? These units are shaped differently.
If these are the right ones, how do you bolt the mount to the crossmember as there is no central stud?
Is the center hole tapped for threads and you run a bolt from underneath?
Is there a preference between the two brands?
It comes with a threaded stud that you must "double-nut" to tighten into the bushing and it has three threaded holes in the bushing(1 for one bolt design and the other 2 for the two bolt design). Once you thread the stud into the mount, you put a bolt on from underneath like stock. I dont know what you mean by the "failsafe locking design" but thats definitely the mount that I installed.
I had heard that Prothane was really rough, and after I installed it there was a ******* earthquake underneath my car at 2000rpm to redline, also at speeds of 65-80mph. Im telling you, IT WAS BAD.
After a 1000mile trip to Lake Tahoe and back, some city driving and some street racing its gotten better, but it still vibrates at freeway speeds.
Ive heard that Energy is slightly softer but I havent experienced one.
It shows the threads I wasn't sure about as well as an internal failsafe design. If the poly ever breaks the metal tabs INSIDE will contact and limit movement.
'02 WS6, if it is so bad why not replace it with a rubber one?
Does it at least feel better from a performance standpoint?
After doing some more reading I'm probably going to grind off the bumps and leave that plate off. If the new mount is still taller than the original, I bought 8 thin rubber washers and 4 thin metal washers. I will place 2 rubber washer on each bolt between the crossmember and body. If the crossmember needs to be spaced down some more to retain the stock driveshaft angle I will add the metal washers to the rubber ones.
I know the poly bushing by itself is going to be stiffer than the rubber one, so why would I not do everything I can to soak up any vibrations?
I will be replacing the TA bushing pretty soon when I can find one.
Energy Suspension
Prothane
I have had one Energy Suspension and one Prothane trans mounts in my car to date. I put the ES one in about 3 months after I got my car and yes, the vibration is slightly more than stock but insignificant if you ask me (personally I laugh when I hear people whine about vibration in a performance oriented car........if you want a Cadillac, buy a Cadillac
). That was 4 years and 50K miles ago. When I did my motor swap I noticed that the poly had some small cracks starting to form in places so I felt "since the transmission is out anyways.....whats $20 so I don't have to play with it again." This last time I put a Prothane mount in because thats what a local place had in stock. To me, Poly is Poly......whatever you can get your hands on/find the best deal on will work fine....
you will reuse the stock bolt to connect the poly mount to the transmission......then buy a standard Grade 8 bolt (I think it's 5/16-24) from ACE to bolt the poly mount to the transmission crossmember.
Do you really need a different bolt? I wouldn't think so.
depends if they are the right size or not........
The center hole in the trans mount is threaded and the mount comes with 2 bolts. The bolts do thread into all 3 holes, so I think the ES bolt will work just fine as long as it is long enough and I think it is.
I do notice that the tranny is a bit higher so I will probably drop the crossmember when I replace my TA bushing and put a total of 3-4 rubber washers as well as maybe 2 thin washers per bolt. That should drop the tranny just a little to where it should be as well as add a little more cushioning.
The shifter feel is much improved. I run the Hurst Billet Pro and it does feel better. I still get some engine torque which can move the **** maybe 3/4" under throttle. I plan on swapping the drivers side engine mount with poly soon.
So for those who want to run the ES tranny mount, leave off the preload spacer, grind off the 2 bumps on the bottom and figure adding 1/4" worth of washers to space the crossmember down.
I'm going to use a combination of metal and rubber washers to get my 1/4" or so of space.
I'd recommend this mount to everyone who has a manual tranny.
I was mainly suggesting that to '02 WS6 and possibly other Prothane users. I'd rather have some washers handy for the install in case I needed them than not have them and end up with the tranny touching the floorboard. You know what I mean?
They even sell the motor mounts individualy so changing one side only makes good fiscal sense. I've heard a lot of folks change only the left with good results. That's my reasoning for doing only that side.
I'm running a lot less power, stock in fact. I don't drag race either. Mine is more of a road race daily driver.I've heard of people using metal stock shaped mounts, but combined with tlots of power it may distort the block or even break it after a while.
I wonder, in my case, if a solid motor mount on the drivers side would be fine for the engine? It would still have some flex from the right side mount so maybe I should took into those.
As you can tell, I don't know much about the mounts, poly or solid, for these cars and all the little tricks associated with them. I think I have a pretty good bead on the tranny mounts.
If you have some suggestions on solid motor mounts, let me know. I want to get rid of the shifter movement under acceleration. There have been times in the past where it torqued to the point 1st gear was almost where 3rd gear should have been. Getting rid of the play would allow me to shift with more confidence, I'm sure.
https://ls1tech.com/forums/showthrea...86#post3333486
