gains from flywheel?
Old Aug 10, 2005 | 10:05 AM
ls1jimmy85's Avatar
Default gains from flywheel?
has anybody witnessed any hp gains from a lightweight flywheel such as a fidanza, just curious...
thanks
Old Aug 10, 2005 | 10:48 AM
2001CamaroGuy's Avatar
thanks
don't have a HP gain number but the car sure ran/accelerated much nicer with the aluminum flywheel..............
Old Aug 10, 2005 | 12:15 PM
ls1jimmy85's Avatar
thats good to hear, any body else?/
Old Aug 10, 2005 | 12:27 PM
98SuperSport's Avatar
im sure you're doing the clutch at the same time too right....i think you oughta get better throttle response too with the flywheel, a little HP
Old Aug 10, 2005 | 02:03 PM
titus2669's Avatar
From what I know. Your not gaining any hp, your just freeing up the hp that is there.
Now im not sure how much you free up but I hear is a pretty good mod. Im looking into it myself.
Old Aug 10, 2005 | 02:48 PM
true.....light weight parts don't actually make you "build more HP"...the ONLY way to BUILD more HP is to burn more fuel/air and exert the resultant pressure over more bore/stroke.........
but for simplicity sake, "freeing HP" is looked at as "building HP" because it is HP you were not able to use towards pushing the car down the road/track........I would say it's an easy 10-15HP if I had to guess.....
Old Aug 10, 2005 | 02:58 PM
ls1jimmy85's Avatar
so i guess the real qestion is how much rear wheel horsepower is it freeing up. i understand. i should have dyno results within the next two weeks and im getting the luk z06 clutch as a cheap slight upgrade.
Old Aug 10, 2005 | 03:42 PM
10....15............
don't waste your time with the Z06 clutch........
Old Aug 10, 2005 | 03:50 PM
LS1BirdDRG's Avatar
11 Second Truck Club
If your just doing autoX like your sig says, the Z06 clutch should be okay. I've had good luck with mine even with "alittle" dragracing.
I'm only about 400rwhp so you do have alittle more than me though.
Old Aug 10, 2005 | 04:33 PM
it will probubly work for his application, I would just like to have "extra" in case I find more power somewhere (like a big supercharger )........
my point is, the cost for the clutch isn't NEAR what the install cost is and IF down the road he wants to do something that needs more, he is already good to go.......
Old Aug 10, 2005 | 04:49 PM
blazinws6kush's Avatar
i had installed a spec III, all new hydraulics, and fidanza aluminum flywheel. it feels like my car has faster acceleration in 1st and 2nd. i though i would warp but i has held up great!
Old Aug 10, 2005 | 05:59 PM
LS1BirdDRG's Avatar
Your definately right about that. Saves work in the future.
I went the budget route with mine (since I did the labor) and it's held well considering...
By Brett Foote | 2026-06-04 05:00:17
