View Poll Results: Are you happy with your textralia clutch?
Yes
192
74.42%
No
66
25.58%
Voters: 258. You may not vote on this poll
Textralia poll are you happy with it..
Originally Posted by gametech
I haven't received mine yet, but any engagement problem seems like an adjustment issue that the shop who did the install should take care of. If the clutch made funny noises, didn't hold, etc., I would be worried. If it just catches too high or low, I would make the shop fix it.
Robert
Originally Posted by mario65
Just had NLperformance install it. It grabs too low. Will take some getting used to. Second and third seem to be getting harder to find. About 50 miles now. Seems like it may not be releasing completely?
You will probably have to shim up the slave cylinder, I had the same problem with other clutches. Got sick of shimming and bought Mcloed adjustable master.
Thanks for the responses. I feel pretty good Pete will help me get this right. He has always been there to answer my q's. Very unusual to have someone talk to you and help you with their product as well as he has. I will take it back to NLPerf and hopefully he can talk them through it. It actually shifted into gear better when I first picked it up. I hope the tranny didnt suffer some damage trying to bed it in without complete disengagement. I put about 200 mixed miles on it and still no improvement. The pedal is very soft the first half of travel then it seems to get harder just as it disengages. I haven't got a clue what it is. Maybe bleeding,and maybe shimming though Pete says it has not been necessary yet.
If ever I have a low pedal again I will NOT drive the car until the clutch grabs where it is supposed to. I am worried about the tranny.
Originally Posted by steveo346
i honestly have never even heard of that clutch, but sounds like its a good one
Robert
1 Post
Originally Posted by TurboDan
Pedal is slightly lighter than stock. With over 1,500 miles on the clutch it is as broken in as I expect it to be. Drives great and grabs great! There is some chatter if I'm not real careful with the release at launch. Also chatters if I am cruising slowly with the clutch released, and rengage without rev matching. I think this just the nature of an aftermarket clutch that doesn't slip like the stocker.
I give it an A+ so far!
#33
awsome clutch IMO...1500+miles on mine thus far with appox 15 passes down the track...thats over 600rwtq and this thing hasnt skipped a beat!! my only curiousity now is to just how long this thing is gonna last with the abuse. Robert has quite a few more passes than i do so so far its lookin pretty good.
#34
Originally Posted by hugger1975
well, I broke my rear after breaking in this clutch.
#36
#37
Ok guys we know have 7 or so unhappy campers.Maybe some of you that originally said you were unhappy have been fixed up and mabye some of you still are. Maybe time for some more explanations on what the reasons are for you not being happy.
I am still sitting on the fence but the percentage of people that like it is still a lot higher than those that don't.A good thing so far.
#38
Some guys may not like it because of the puck design (racing like), meaning you can get some shake/shudder until broken in and/or learning the correct take off rpm. My set-up works best taking off from idle, this eliminates all chatter. If I try to take off like stock clutch I get mucho chatter/shake. Still, I bet none have failed, try that poll with other brands.
Robert
Robert
#39
should have my tex clutch early this week. cant wait to get it installed.
i think ur sig needs an update. i dont think the clutch is slippen anymore best of luck with a new rear
so, yeah it grabs like a *****.
and its got the best pedal feel
