doing clutch install toaday....question
You have to take the trans first, then the bellhousing. You can't get at the bolts to remove the bellhousing w/ the trans still installed. Just no room <img src="gr_sad.gif" border="0">
The RAM plate i use is a 3000 lb static clamp force.
I'm guessing you'll be ok w/ the ~2600 plate. As the stocker is in the range of 1800, and the SPEC's were getting away w/ a stock clamp force and aggressive material.
I'm using the 6100 series disc, and it's a no **** clutch. When it grabs, it grabs.
I fear i'm going to blaze new teritory w/ the new motor this year. Should be fun, and i'm fairly certain the RAM is on the way out.
Do you have the 900 disc now??
good luck trying to get at the bolts <img src="gr_stretch.gif" border="0"> you're gonna need it if you try to get it out in one piece.
http://people.atl.mediaone.net/lanie...s/Image002.jpg
http://people.atl.mediaone.net/lanie...s/Image003.jpg
http://people.atl.mediaone.net/lanie...s/Image004.jpg
http://people.atl.mediaone.net/lanie...s/Image005.jpg
http://people.atl.mediaone.net/lanie...s/Image006.jpg
http://people.atl.mediaone.net/lanie...s/Image007.jpg
http://people.atl.mediaone.net/lanie...s/Image008.jpg
At least guys will know NOT to use this....and as far as the 6100 being a "no ****" clutch <img src="gr_grin.gif" border="0">
Well just got back from that clutch place and he did turn my flywheel for free so it could be worse. Now I just have to go to Barnett tomorrow and get the RAM stuff but the "145" slave wont be here till between Wed-Fri <img src="gr_sad.gif" border="0">
[ February 11, 2002: Message edited by: cablebandit ]</p>
