6 speed cranks without pressing in the clutch
Old 10-08-2005, 04:18 PM
Silver02TA's Avatar
Default 6 speed cranks without pressing in the clutch
just got a Z28 that starts without pressing in the clutch...
why does it do that? did someone wire her to do that i wonder?
Old 10-08-2005, 04:30 PM
brandon1221's Avatar
Mine does the same thing.
Old 10-08-2005, 05:10 PM
8-Pack's Avatar
I cant imagine it would be that hard, all you would have to do is hardwire the switch. Never done it myself though.
Old 10-08-2005, 07:22 PM
Zymosis's Avatar
Does it have aftermarket starter on it? Or any type of aftermarket keyless entry?
If not, im assuming it was installed at one time, and they didn't take that 'feature' off.
Old 10-08-2005, 10:14 PM
lsp408's Avatar
check your fuse
Old 10-09-2005, 12:38 AM
rollinna65's Avatar
could be from a keyless remote starter
Old 10-09-2005, 04:27 AM
618HAWK's Avatar
Sounds like it might be a stuck or-faulty clutch pedal interlock switch.
Old 10-10-2005, 08:46 AM
underatedT/A's Avatar
my interlock switch had spun out causing it to start without the clutch engauged i guess this happens to older f-bodies
Old 10-10-2005, 10:05 AM
BTLFEDSS's Avatar
Yeah its probably the clutch safety switch they are only like 6$ and take about 5 minutes to swap out happened to me and i failed tech at the track
BTLFEDSS
