Pro 5.0 Noise????
Old Feb 13, 2002 | 10:51 AM
chev4life's Avatar
Default Pro 5.0 Noise????
I just installed a Pro 5.0 shifter on my '02 SS last night but now I have alot of tranny noise or whatever it is in my cabin. Is there a way to cut this down some??? I even used some rubber gasket material and RTV on top and bottom of it to make a better seal to the tranny. The shifter feels great in shifts except when going into fourth I have to put a little more into it and it makes a metal on metal sound. Anyone have any of these problems, if so, or you know anything that can help.....HELP! <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old Feb 16, 2002 | 11:58 AM
Bob2of3's Avatar
Wheels up Director
Default Re: Pro 5.0 Noise????
TTT for Chev4life <img src="gr_stretch.gif" border="0">
Old Feb 16, 2002 | 01:45 PM
WeatherGuy's Avatar
One of the dirty little secrets of some upgraded shifters is the increased cabin noise. It is not something you think about until after you install the shifter. I have it, 'course it now gets lost in high lift valvetrain noise and exhaust roar when I stomp on it.
Old Feb 16, 2002 | 02:43 PM
XFiveLiter's Avatar
The stock shifter I believe, has bushings or
isolaters. These bushings, while they make the
shifter quiet, also contribute to the mushy,
unconnected feel. The Pro 5.0 eliminates the
bushings, giving a more positive feel, the tradeoff being the extra noise.
The extra effort required to shift, is due to the
shorter stick which gives the shorter throws.
Old Feb 16, 2002 | 03:47 PM
99 Black Bird T/A's Avatar
My car picked up a fair amount of noise with the Pro 5.0 too. I just play the stereo louder. When I add the Hookers and a cut out I don't think the shifer noise will be much of an issue. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Feb 16, 2002 | 03:51 PM
A friend of mine has a Pro 5.0 in his 94T/A and his car pick up some noise too not as much as mine did. His 00 FireHawk has the Hurst which is a good shifter much better than stock but has virtually no more noise than the stock shifter. Personally, I don't think the Hurst is quite as good as the Pro 5.0 and I don't like the Hurst higher handle but that's just me.
Might try to find a Factory Hurst someone's swapped out for a few bones.
Old Feb 17, 2002 | 07:11 AM
BobP's Avatar
Goto LS1.com and do a search for the Rob Mod. I haven't tried it yet, but it sounds like it should deaden some vibration.
