Bendix Slave
Old Oct 18, 2005 | 12:25 PM
TransAmGT's Avatar
Default Bendix Slave
I think i'm gonna go with the Bendix
It's 50 bucks cheaper and should work the same as the 01/02 GM slave...what do you guys think?
Old Oct 18, 2005 | 12:48 PM
IllusionalTA's Avatar
Well if it's designed to be used as a OE Replacement i don't see why it wouldn't be a bad swap.. don't know if it's a upgrade though...
Old Oct 18, 2005 | 08:30 PM
TransAmGT's Avatar
Well for a Pre 01 car it would be as this is suposed to be a 01/02 slave b/c the 98-00 SUKED
Old Oct 18, 2005 | 10:48 PM
slowscott's Avatar
does it come with the line that is drilled for the drill mod? I wanted to drill that first before taking my car apart to minimize down time. What advantages does an 01+ slave give you?
Old Oct 18, 2005 | 10:52 PM
TransAmGT's Avatar
You can't even get the 98-00 slave anymore they discontiued it b/c it suks...the seals are better in the 01/02...and you can do the drill mod at the same time...only take a few minutes
