View Poll Results: Is the lighter upgrade shaft worth the extra $$$?
3" aluminum stocker with 1350 joint
18.75%
performance steel shaft custom length upgrade
50.00%
3.5" aluminum .125 thick wall custom length upgrade
31.25%
Voters: 16. You may not vote on this poll
driveshaft poll
Old Nov 16, 2005 | 08:16 AM
pasbonsimon's Avatar
Default driveshaft poll
Driveshaft poll for a 500RWHP (including a 100 shot) drag radial only car
performance steel upgrade
3.5" aluminum .125 wall
Is the 3.5" aluminum worth the extra $$$?
I put the poll here because its an M6 and the auto guys don't seem to worry to much about upgrading driveshafts.
Old Nov 16, 2005 | 10:25 AM
SUTTERERMAN85's Avatar
go with the stocker and the 1350 joint. if it breaks then upgrade. how much does the 3.5" alum cost? steel would be the strongest but a little heavier.
Old Nov 16, 2005 | 11:11 AM
the Mark Williams 3.5 aluminum shafts start at $489
steel is cheaper and twice the weight
so how much RWHP am I gonna lose with a steel shaft? A search yeilds no results....
Old Nov 16, 2005 | 11:42 AM
NLinnear's Avatar
With nitrous, I would go with a steel unit. You don't want to see what happens to your car when a driveshaft breaks; loop or no loop.
Old Nov 16, 2005 | 01:27 PM
Steve Burger's Avatar
LS1TECH Sponsor
Steel and you can expect to loose about 5 RWHP. Even with a loop it is expensive to break a shaft.
Old Nov 16, 2005 | 02:08 PM
CHEVYXTREME_00's Avatar
If you want steel you can get one made out of cromoly or if you want the look and stength factor carbon fiber is really good.
Old Nov 16, 2005 | 02:28 PM
n2ojunkie's Avatar
You forgot to add a stock steel ds to the list. After I twisted my alluminum I went with a steel one to get it back on the road and its held everything I have thrown at it so far.
Old Nov 16, 2005 | 02:49 PM
Turo's Avatar
I'd go with a steel for an M6 on spray, even if its on DR's and not slicks. IMO, just build it right the first time.
Old Nov 16, 2005 | 03:11 PM
02 Camaro SS's Avatar
Keep in mind that a steel shaft is harder on your rear since it flexes less.
Old Nov 16, 2005 | 04:13 PM
the rear is a Moser 12 bolt -
if an upgraded steel shaft weighing twice as much is only going to cost me 5-RWHP that may be the way to go. I was anticipating more like 10-12.
Old Nov 16, 2005 | 04:27 PM
nice website that TTP stage 4R H/C is bad ***
Old Nov 16, 2005 | 06:14 PM
flash12t's Avatar
how much can power can a carbon fiber drive shaft handle. .??
Old Nov 16, 2005 | 06:21 PM
Tally TransAm's Avatar
www.pstds.com
Old Nov 16, 2005 | 06:30 PM
smokeum99ta's Avatar
Steel ... Its stronger and cheaper. Who cares if it weights a little more or if it costs you a couple of hp , just remember that'll be last you buy as long as you take care of your u-joints.
Old Nov 16, 2005 | 11:04 PM
wrencher's Avatar
wrencher
What about chrome moly? Billingsely offers them from by stange.
Mine stayed together even when I broke my torque arm at the line.
https://ls1tech.com/forums/drag-racing-tech/402689-broke-spohn-torque-arm-w-e.html
I'd have to weight it but dont seem to be alot heavier than the aluminum stocker.
Old Nov 17, 2005 | 08:39 AM
LS1TECH Sponsor
I have the Strange from Billingsly. It is a DOM tubing and a very nice peice. It is not a lot lighter than steel.
Old Nov 17, 2005 | 10:33 AM
Originally Posted by Tally TransAm
Chromoly Driveshafts
For high horesepower applications 1200+. Seamless 4130 tubing with chromoly heavy duty 1350 yokes and cryo treated solid u-joints. Welded within .0010 total runout and electronically balanced to insure smooth operation. Price: $339.00. A complete line of forged transmission slip yokes is also available.
This is very interesting- gonna find out what it weighs
Thanks
Old Nov 17, 2005 | 10:48 AM
and a fair price as well.
Thanks
Old Nov 17, 2005 | 11:53 AM
pontiac's Avatar
I got my drive shaft custom made fro 220. huntsville drive shaft, he has been making rqacing drive shafts for 30 years.
Old Nov 17, 2005 | 03:37 PM
Ace$nyper's Avatar
I've never seen a problem with steel
Alum i tend to avoid too many horror stories
C/F price range is quite high although I really would like to try one.
C/M is probbly how i'll end up going.
