Drill Mod...What size drill bit??
Old Nov 26, 2005 | 07:57 PM
Xtnct00WS6's Avatar
Default Drill Mod...What size drill bit??
I read on install university that for the drill mod you need to use a 1/8" drill bit but when I put that bit in it goes in just fine. This was in the end that goes into the master.
What part of the hyraulic line am I supposed to be drilling? If it's the part that connects to the master, then what size bit?!
Old Nov 26, 2005 | 08:28 PM
SScam68's Avatar
Did you buy the car used?
I could fit just the tip of the bit in on my line, had to drill out the rest.
Old Nov 27, 2005 | 01:08 AM
Xtnct00WS6's Avatar
Yeah...I bought it used. What end am I supposed to drill out though?
Old Nov 27, 2005 | 01:23 AM
SScam68's Avatar
Well there's only one lol. The master side.
Old Nov 27, 2005 | 05:32 PM
Xtnct00WS6's Avatar
Ok...I figured it out.
The restriction is about an inch from the end. It's not at the very end like I thought. Reading through the install university write up thew me off because it sounds like it's at the very end of the line. Also the part u have to drill out is the part that connects to the master.
Old Nov 27, 2005 | 05:36 PM
wrencher's Avatar
wrencher
Just dont let it get real hot while you drill it the line can get damaged.
Go slow & feel the area of the restrictor, keep the heat down while doing it. Douse it in brake fluid if you have to.
Old Nov 28, 2005 | 08:11 AM
oange ss's Avatar
i used a 9/64
Old Nov 28, 2005 | 01:02 PM
bradl1982's Avatar
1/8 inch
Old Nov 28, 2005 | 04:42 PM
bad6as's Avatar
if i but a new master to go along w/ the trexdila clutch im geting, am i gonna have to do the drill mod to a 01+ master
Old Nov 28, 2005 | 06:09 PM
oange ss's Avatar
the restrictor is in the line on the master side, not in the master itself, but it would behoove you to do it while you're changin your clutch
