M6 and 12 bolt =No No?
Old 12-18-2005, 01:23 PM
  #61
smokeum99ta's Avatar
Originally Posted by SKI
12 bolt is a great rear.i have one in my 67 chevelle for years and have not had any problems with it .A 9 inch rear takes more horse power to turn than a 12 bolt.
At this point I don't care if it robbed 50 hp i'm tired of my car being down because of the same problem over and over again.
Old 12-18-2005, 07:22 PM
  #62
bww3588's Avatar
it uses 5 percent more hp to turn than a 12 bolt. moser re engineered their 12 bolts to prevent the axle tube flexing. the new ones wont flex. the will hold up to 1000 hp before they break.
Old 12-18-2005, 08:47 PM
  #63
chpmnsws6's Avatar
so if your car has 100 hp it only takes 5hp more but if you make 1000hp it takes 50hp more?
Old 12-18-2005, 09:18 PM
  #64
bww3588's Avatar
no it takes 5 percent more to turn a 9 inch than a 12 bolt meaning if it takes say 10 hp to turn the 12 bolt it takes 10.5 to turn the 9 inch.
Old 12-19-2005, 12:31 AM
  #65
Silas2k's Avatar
Originally Posted by bmfcamaro
just get a 12 bolt or 9" whatever, nice clutch (i have stage 4 spec), and some et streets. i didnt just go out and do it. i increased on each run. start around 4000 to get the hang of it. when i get it tuned nicely it should be a whole lot a fun
theres a guy locally here doing 1.6xs slipping at 5.8k-6k with bolt-ons on drs and with completely stock suspension/10-bolt, go figure
Old 12-19-2005, 12:48 AM
  #66
MASS seller approved
Time2Kill's Avatar
The 5% refers to the efficiency lost. So if you are losing 5% in efficieny, then you would be correct in saying 5hp for 100hp, or 50hp loss for 1000hp. Same with a tranny, a tranny is at a set efficiency rating, not a set HP lost rating.
Old 12-19-2005, 10:54 PM
  #67
Stu'sWS6's Avatar
12 bolt here. The car is pretty much dead hooking a 7400 rpm launch w/o even a peep out of my spooled Strange 12 bolt
Old 12-20-2005, 04:11 AM
  #68
chpmnsws6's Avatar
We need to line em up next season for a wheels up picture shot.... kinda cool seeing two M6 white ws6's running at the same time
Old 12-20-2005, 06:57 AM
  #69
Black FormulaLs1's Avatar
so a 9" is the best choice for an M6 car right? how much they go for? will be looking at one come tax season...and no my 99 formy doesnt have tract control
Old 12-20-2005, 04:32 PM
  #70
Stu'sWS6's Avatar
Sounds good. Any chance you could make it to KCIR on 3-11-06? We are having a GM shootout there. The track always hooks-me and TOSTO RACING both had new bests last time out there.
Info here: https://ls1tech.com/forums/midwestern-members/421453-mo-fbody-shootout-3-11-06-open-all-gm-makes.html
Old 12-20-2005, 06:02 PM
  #71
chpmnsws6's Avatar
man that sounds fun. i'll bust my a$$ trying to get the car ready for it!
Quick Reply: M6 and 12 bolt =No No?
