View Poll Results: Notchy or not
Yes its Notchy
36
69.23%
No its NOT Notchy
4
7.69%
Not the smoothest but a little Notchy
12
23.08%
Voters: 52. You may not vote on this poll
Tranny NOTCHINESS?
Old Dec 18, 2005 | 01:33 AM
CraZee ZO6's Avatar
Default Tranny NOTCHINESS?
Hey guys,
My tranny feels real notchy in this weather? I dont know if its the weather but the tranny is definetly notchier than it used to be. Had some BIG runs today with some BIG cars and I missed 3rd once and I know it wasnt me but the tranny is making things HARD!!
How do you guys feel?
Maybe I need a new clutch (still stock) does that effect tranny notchiness?
-Zee
Old Dec 18, 2005 | 06:39 AM
itchygomey98's Avatar
I could be misinterpreting your use of the word nothiness, but it sounds to me like your shifter bushings are colder than normal. This results in it feeling more stiff.
Old Dec 18, 2005 | 10:08 AM
chpmnsws6's Avatar
why is it in advanced tech? this is for the manual forums
Old Dec 18, 2005 | 10:12 AM
Not sure. Maybe it's an advanced transmission??
Old Dec 18, 2005 | 10:17 AM
chpmnsws6's Avatar
one of them there fancy t56's. this ain't no top loader HAHA
Old Dec 18, 2005 | 12:27 PM
Worm's Avatar
My Z06 always felt like you were hitting something in the path between gears. My Transam never felt like that... and its definately worse in the cold.
Just normal M12 vs M6 differences?
Is it the carbon fiber blocker rings in the M12? Thats my only idea.
Old Dec 18, 2005 | 04:17 PM
lowchevy2go's Avatar
my ws6 is super notchy, when i shift into gear its like it goes in twice, there is like 2 clicks goin into gear i hate it ! Damn T-56 crap !
Old Dec 18, 2005 | 06:24 PM
Zentenk's Avatar
I have this as well... I missed a shift racing yesterday. Like switching from first to second is clunk, clunk. Would changing fluid help? It is my first manual car and I bought it in June. It will hardly ever go into 3rd when racing but driving around it feels like I have to pass through a lil swing door or something, like i'm popping its cherry every time.
Old Dec 19, 2005 | 01:07 PM
LS1TORQ's Avatar
same problem here, i'm thinking maby its time for new synchros.
Old Dec 19, 2005 | 01:49 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I think there are a lot of people that have this problem with the T-56 trannies...mine gets better as it warms up, but the 1-2 is almost always a "clunk clunk" type of shift. I'm already budgeting for a rebuild that will hopefully cure some of that.
Old Dec 19, 2005 | 01:50 PM
Fenster's Avatar
Every T-56 is notchy IMO. They are not the smoothest shifting transmissions by any means. Mine is definately a lot notchier when it gets cold. Until the car gets warmed up and I drive for a while, its really notchy. Its notchy all the time, probably not as much as you are describing, but I really don't mind mine. Only time it sucks is when its really cold and I am shifting hard...
Old Dec 19, 2005 | 05:09 PM
tici's Avatar
Another member here of the "clunk clunk" club!
My tranny is a 97 Borg Warner.
Apparently the BW are known to be like that, the Tremec should be better... but after looking here and there I think every tranny is acting a little different. Some gets better results with a different fluid. But the "good fluid" is never the same, so everyone will have to find his personal best one
There is a similar thread here http://www.z06vette.com/forums/showthread.php?t=36285
Those guys have a different tranny but still the same problems as us.
Some shift fine, other clunky.
Old Dec 19, 2005 | 06:11 PM
2000 TAWS6's Avatar
Maybe related, maybe not.
I just dumped the Royal Purple Syn ATF I had put in 3K miles ago and switched to plain old Dexron III.
My trans shifts MUCH smoother now than it did with the synthetic in it.
Are you all running standard Dexron III ATF in your T56's?
Old Dec 19, 2005 | 06:36 PM
zdawg28's Avatar
Has anyone ever had this problem, rebuilt the transmission, then had the transmission shift smoother. Mine use to shift super smooth, but has only been getting worse. Needs a good t-56 rebuilder
Old Dec 19, 2005 | 08:59 PM
Zentenk's Avatar
I have no idea what fluid is in mine but I will be changing it when I get the chance right around spring time. I also may need to drill the slave/master cylinder crap.
Old Dec 19, 2005 | 09:03 PM
N3V3RL8T's Avatar
I just had mine replaced after 96k miles and its a lot notchier.
Old Dec 19, 2005 | 09:04 PM
CraZee ZO6's Avatar
You guys are right.
If I drive the car a good 20 mins rowing the gears around town it gets smoother. The longer the better. Its probably because of the 25-30F days here in NY.
Its definetly something I got used to already, just cant SPEED SHIFT as fast when hauling ***.
-Zee
Old Dec 20, 2005 | 11:08 AM
pasbonsimon's Avatar
notchy here with Dextron III
Old Dec 20, 2005 | 12:19 PM
Robinator's Avatar
ditto
Old Dec 20, 2005 | 10:18 PM
jerflash's Avatar
ya man here on long island its ben so cold that that first 1-2 shift is really notch!!!!
i actually make it a point to skip 2ed all together for like 5 mins
and my t5 was just rebuilt to viperspec less then a year ago
