View Poll Results: High HP clutch choice.
Spec Stage 3+
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
12
27.27%
Spec Stage 5
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
20
45.45%
Centerforce Dual Friction
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
12
27.27%
Voters: 44. You may not vote on this poll
High HP Clutch Poll!
Originally Posted by ls1charged
ok so the centerforce is junk.....so what are the differences between the Spec 5 and 3+?Also anyone have links to where i can get either or the Mcloud cheap?I already have a flywheel and new slave and master.
I would get a new flywheel with the new clutch so you have everything brand new. Sell your current flywheel.
37-64048B-00-07 McLeod Street Twin Dual-Disk Clutch, Steel Flywheel (Master cylinder NOT included), 1998-2002 LS1 F-body $815.00
37-72801-07 McLeod REV-LOK II Clutch Kit, includes sintered iron clutch disk and stock style pressure plate. 1998-2002 LS1 F-body, 1997-2002 LS1 Corvette. (Slight modifications required to work with factory flywheel.) $699.99
I don't know what the REV-LOK II clutch kit is. Call Thunder and ask. I am sure there are other sponsors which sell McLeod but Thunder was the first that came to mind.
Good luck
Andy
Originally Posted by White.Lightning
Thunder Racing:
Good luck
Andy
Good luck
Andy
6600 rpm clutch dump of death Administrator
Having been through the following:
Stock Z06
McLeod Dual Disc
Exedy Dual
Textralia
I'd recommend the Textralia. Best clutch I've used. The McLeod has too much mass, and you can't powershift it well even with the AL flywheel its heavier thana stock single disc clutch. Ours started slipping after 40 passes.
Stock Z06
McLeod Dual Disc
Exedy Dual
Textralia
Originally Posted by Nate_Taufer
Yes you could because that's probably how many spec clutches it will take you to realize you should have bought a McLeod street twin in the first place.
But my vote is for the RPS unit. That's what I'm running.
Nate
Nate
#33
thats outta my league i cant see spending $1200 on a clutch.i could buy 2 Specs for that price.Please choose from the 3 posted. This is a street car btw.thanks again guys the more the merrier.
Gotta pay to play, my friend.
That said... none of the above are a good choice.
CF will NOT hold it.
Spec has a variety of problems, primary of which is not really suitable for street use, even if yours doesn't go boom.
Search... this has been discussed a bunch of times, latest concensus seems to be Textralia. As far as customer service... when the spec goes boom, don't expect much help. Textralia has an EXCELLENT cs reputation. Something to consider.
#36
I wouldn't even bother with a spec 3. I tried two of them and they wouldn't hold 500+rwhp very well. one made it about 40 passes, the next about 10. swapped to a spec 5 and its doing very well. made about a dozen passes with 680rwhp on a 100shot and about 50 passes on motor, 550rwhp. no signs of slipping, but occasionally it sticks to the floor if I don't let it cool down.
(I think this is a hydraulic problem, not a clutch problem)
#38
Originally Posted by Slowhawk
I like the SPEC 5.Peddle pressure is stock or even softer than stock and it drives great in traffic.
Mcleod is a 50/50 .I've pulled out a good share of blown up one's.
RPS- I hated it.Lasted 1k miles in my Vette and they didn't stand by there product at all.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
