Can cold affect the clutch?
Old Dec 31, 2005 | 02:51 PM
Shamson5.7's Avatar
Default Can cold affect the clutch?
Last night it was quite chilly out and it felt like my car had no power to the ground. Its a lot warmer today and it doesnt have the same affect as last night. Do cold temperatures make that big of a differance?
Old Dec 31, 2005 | 06:42 PM
tippmann243's Avatar
temperature can make the hydraulic fluid thick, making for slow clutch engagement
Old Dec 31, 2005 | 08:17 PM
Ferocity02's Avatar
My clutch seems like it's harder to slip when its cold. As the flywheel and PP warm up its much easier to drive.
Old Dec 31, 2005 | 08:23 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Also if it's really cold,the block of ice on the floorboards will make it very difficult to depress the clutch pedal fully. ....HAPPY NEW YEAR ----ALMOST!!!
Old Dec 31, 2005 | 08:57 PM
Shamson5.7's Avatar
Its wierd because even after a small drive when its cold out it still has the same effect. I jumped back in the car today (it was 65ish) and the SOB took off like crazy! i had no problems with it at all and very little noise compaired to when its cold.
Old Dec 31, 2005 | 09:01 PM
NHRAMAN's Avatar
Seriously though,when its cold the fluid is thicker...when the car is warmed up the pedal effort is slightly less......
Old Jan 2, 2006 | 04:42 AM
brad8266's Avatar
Old Jan 3, 2006 | 06:27 PM
angel71rs's Avatar
Slow disengagement too. 1st time I drove my 98 (wintertime), I ground gears going from 1st to 2nd. It had been a while since I had driven a manual and thought I'd lost my skills. But once it was warmed up I was able to row gears no problem. So when winter comes around, I'm very deliberate about waiting a beat from when I push in the pedal to when I stir the stick.
Another quirk I noticed on these cars: it's tough sometimes sticking it in 1st gear. I bought my car w/47k on it, so thought maybe synchros were shot. Until I read this thread:
http://forums.corvetteforum.com/show...1&forum_id=101
T56 quirk???? So I adopted what one poster suggested, I kind of pull it toward 2nd, then it easily goes into 1st. Kind of sad that a modern tranny like a T56 shifts like a truck tranny, but the Muncie in my 57 shifts like butter.
