clutch upgrade
Old Jan 24, 2006 | 12:02 AM
ss 4rM dA BaY's Avatar
Talking clutch upgrade
hey, im new to this forum, but i would like to know if anybody has any suggestions on what type of clutch would be the best to go with. right now i have the stock clutch for my 02 ss. i was told centerforce was a good option but if anybody knows better it would be appreciated.
Old Jan 24, 2006 | 01:31 PM
HandsomeBWouderful's Avatar
Go run some searches for Ram, Spec, Centerforce and McLeod in the Manual Transmission forum. You will get more than you want to read there . Then go visit a sponsor on th right ---->
Old Jan 24, 2006 | 01:42 PM
777's Avatar
777
I'd get a ram 910. If you want a light pedal I'd get the z06 clutch kit. (if you plan on staying stock or bolt-ons only) I've got the z06 and it's holding fine. I'm close to 400rwhp.
Old Jan 24, 2006 | 05:35 PM
00T\A's Avatar
I'am also running the Z06 Setup an loving it.
I 'am also very close to 400rwhp.
But i must say that my car never see's the track an is also on street tires.
Old Jan 26, 2006 | 12:06 PM
98Z28MASS's Avatar
How long has your ls6 held for you and what other upgrades did you do? I am going with a custom grind 232/238 cam come spring time and im still on the stock clutch and want to upgrade but dont want to be throwing over a thousand dollars into the clutch as I dont go to the track more than maybe once or twice a summer if that. It would mainly be a street driven car (not a daily driver) with street tires that wouldnt see hard launches, so would the ls6 clutch be enough?
Old Jan 26, 2006 | 12:25 PM
00T\A's Avatar
You should be fine.
I have a cam only bolt-on car with 392 rwhp.
I have close to 15xxx on my Z06 no problems yet.
Old Jan 26, 2006 | 12:28 PM
00T\A's Avatar
You might wanna look at the LS7 clutch set-up.
I think that is what i will do next time around.
98Z28MASS's Avatar
Wow thats awesome, yea i think i might have to go with the ls6. Besides the clutch what else is needed? DO I need a new flywheel, master cylinder (since mine is a 98), etc? Also where would I get one online? Thanks!
Old Jan 26, 2006 | 12:29 PM
00T\A's Avatar
Yes you will need tp upgrade to the 02 clutch master & slave.
Old Jan 26, 2006 | 12:30 PM
98Z28MASS's Avatar
How does the ls7 clutch compare in price to the ls6? I know id need to get the ls2 flywheel and the ls7 clutch, anything else as my current clutch setup is completely stock?
Old Jan 26, 2006 | 12:34 PM
00T\A's Avatar
I really don't have know much about the LS7 set-up.
Like i said just heard some good things about it.
Old Jan 26, 2006 | 12:35 PM
00T\A's Avatar
Mabye some of the experts will give you a little more insight on the LS7.
Good Luck.
Old Jan 26, 2006 | 01:43 PM
Shadow1999's Avatar
ZO6 and the Textralia being close to the same price; which would be better?
Old Feb 3, 2006 | 02:26 PM
Starz T/A 17's Avatar
Does anyone have the Part number for the ZO6 clutch kit?
Old Feb 3, 2006 | 04:34 PM
Ghostly1's Avatar
12570281 Z06 clutch
Old Feb 3, 2006 | 05:45 PM
Thanks
