PILOT BEARING PROBLEM!! (SPEC II install)
Got my plug ordered today but...
To finally get the sucker outta there I searched around and found a post where some guy used some threaded rod and a nut. Cant find it now though search is jiggy these days.
Anyways I used a 1/2" nut ground down on the sides and a piece of threaded rod and a large 1/2" socket. I slid the ground down nut into the hole sideways and turned it around once in there and then threaded in the rod and nut placed the socket over top with a washer and another nut and presto a puller that worked smooth as butter.
