Downshifting
enough said.
Aside from that, heres something that popped into my mind... A brake booster (in our street cars) relies on vacuum from the engine to operate. When downshifting (and throttle body is closed) the engine is going to create more vacuum, which (in theory) sounds like it would make the brake booster work more efficiently.
Racers downshift to keep power to the wheels and turn fast times.
3rg gear at 50mph will accelerate faster then 5th gear at 50mph.
exactly!
Coasting wastes no gas? I guess if you turn the car off. As long as you hear it the engine running, it is using gas.
But, in the down-shifting defense. It really doesn't kill you to do it. Although shifting from 6th to 2nd at 80 mph won't be very pretty.
My final point is this: braking is used a hell of a lot in professional racing. Brakes work a lot better than downshifting. There is no arguing that.
Mike
Mike
just thought i'd throw that in there.
Worn brakes are worn brakes. Worn synchro rings are going to cause hard/grinding shifts, etc. Grinding transmissions wear the sliders and gear engagement teeth.
