Downshifting
Using this logic makes me question why we even downshift. Of course I'm talking about when you're decelerating, not accelerating
. By not downshifting you're transferring more of the energy and wear it takes to slow down to the brakes, right? Wouldn't that make more sense?? Since brakes are cheap and easy to replace compared the clutch... Wouldn't this cause less wear and tear on the clutch... and the transmission for that matter? IF the clutch is slipping or you notice any accel/decel effects of the shift, your not doing it properly.
The only reason to downshift while decelerating is to prepare yourself for acceleration out of a corner so you do not have to shift in the middle or exit of the corner.
If your downshifting and coming to a stoplight it has NO benefit.
If you want to downshift this way (ie. "double clutch"):
1. Clutch in, Shift into neutral
3. Clutch out
4. Blip throttle to rev to RPM you will be in lower gear
5. Clutch in, Shift into lower gear
6. Clutch out
If you do this properly and quick enough, you will not get the "lurch" that you normally get when downshifting. Also, the shifter will offer no resistance going to the lower gear.
No serioiusly riding the clutch is BAD as a rule because it's basically slipping it which will case wear. This is up or down shifting.
HOWEVER the key to good driving is smoothness so dumping the clutch is not the best manoeuvre , plus if you do this when slowing down it can cause a lot of stress on the drivetrain and unsettle the car.
But the biggest thing with a manual is you can do most/much of the braking with the engine. This gives you far more control than an automatic. Hence ALL circuit and rally cars are always manual and never auto
So yes you should use the engine to brake. If you are driving quick cross country the you should use the brakes as little as possible because the engine will do the rest.
Heel and toe is a good technique, but difficult to perfect and in some cars near impossible due to pedal locations. But if you can "blip" the throttle between down shifts to match the revs then it won't unsettle the car, this allows a smoother faster transition and cornering ability.
Doing this will not damage the gearbox at all, it is common every day practice. Lorry drivers use this to great affect also as the brakes on a big rig are easy to over heat (least in years gone by).
4th to 2nd gear block changes are common as you can go from high speed to lower speed with plenty of control and enter a corner in the correct gear to accelarate out.
another bonus is fuel efficency. When an engine is coasting and down revving it won't be using any fuel. So by maximising downshifting and engine braking you can increase your mpg.
In my TR7 doing that on a daily 50 mile round commute to work and back I could increase my over all average MPG by 3mpg (24 to 27) which is a pretty big percentage.
in my opinion as far as regular downshifting I think it would be harder on the synchro's then the clutch, and I would rather replace a clutch then synchro's.
If done properly, it has no negative effect on your tranny....
Youll find that most clutch problems are from the idiots driving the car.
I love these downshifting threads and all of the theoretical talk about wearing everything out. Thanks for coming in and setting some things right.
Basically, downshifting allows you to slow the car with much more control. Think of driving on icy roads as an example--not a good time to rely on brakes all of the time. A manual transmission has advantages if you learn how to use them. If you drive it like an automatic, then you might as well have an automatic--to take advantages of what it has to offer.
