differences in lt1 t56 and ls1 t56???
im in need of a T56 for my 01 Z and i was wondering if there were any differences between the two (93-97/98-02)? i am aware of the diffent clutch set up but all i need is the actual transmission part no bellhousing or anything else just the transmission.
I think the transmission part are the same, but not 100% positive. I do know that the gear ratios from 94-2002 are the same, but 93's were geared different in all gears but 4th and did not have cags.
I was told that the bellhousing the adapter plate and the input shaft are different because I have one from a 94 camaro that i am gonna use for my swap. What I am not certain of is I read the procedure on replaceing it and from the looks of it the whole trans has to come apart but would be nice if I was able to take off the adapter plate and change the input shaft and install the new adapter plate but im not sure if thats possible.
