Clutch problem on daily driver.....need help!
Do any of you guys have any idea of what this might be, or what I should look at first? Have any of you experienced the same problem? Any input would be greatly appreciated, since this is my daily driver, and I need it to get around. Thanks!
Any other opinions?
p.s. Thanks a ton for your opinion, lowchevy2go!
check and make sure bellhousing bolts didnt come loose (trust me..i know
)replaced master and/or slave.. one at a time or both at once since the slave is a high wear item. pilot bearing should be replaced also since your already there.
