View Poll Results: What Clutch are You Using? (select one or more)
LS1 (Stock)
341
21.05%
LS6
152
9.38%
LS7
182
11.23%
Textralia OZ700
115
7.10%
Textralia Exo-Skel
36
2.22%
SPEC 1
18
1.11%
SPEC 2
45
2.78%
SPEC 2+
33
2.04%
SPEC 3
192
11.85%
SPEC 3+
108
6.67%
SPEC 4
23
1.42%
SPEC 5
26
1.60%
McLeod Single Disc
41
2.53%
McLeod Twin Disc
78
4.81%
Ram VDS 300
4
0.25%
Ram VDS 900
4
0.25%
Ram VDS 980
6
0.37%
Ram VDS 910 "Race"
10
0.62%
Ram HDX
6
0.37%
Ram Powergrip
21
1.30%
Ram Powergrip HD
87
5.37%
Exedy Hyper Single Disc
5
0.31%
Exedy Twin Disc
14
0.86%
Centerforce Dual Friction
132
8.15%
Hays
4
0.25%
SLP/LS6
17
1.05%
ZOOM
12
0.74%
Luk Pro Gold
20
1.23%
Multiple Choice Poll. Voters: 1620. You may not vote on this poll
What Clutch is Everyone Using?
#184
Originally Posted by foxrus14
Is there a difference between the stock LS1 and the ZO6 clutch. Seems like there should be more holding power with the Z06. Just curious. I am thinking it is an upgrade. Maybe I am wrong.
#185
Originally Posted by Talon WS6
McLeod Twin/Aluminum Flywheel Too agressive broke 5 rears including a Moser 12 bolt
But I'm not blaming the clutch, it wheel hopped bad. I like the clutch, got about 50 passes launching @ 4500rpm and 2000 street miles.
---Bill.
#186
I'm going to go the local truck parts ware houses and take them my stock Z06 and see if I can get a medium duty twin plate for cheap. I'll let y'all know how it works. My car is a daily driver. I need stock pedal pressure.
65K miles on it. Many red line side step launches on M/T ET's, plus lots of double clutching in stop and go traffic. Broke close to home. Went to second at about 2kRPM and heard a loud pop from the under the dash some where. Couldn't get into any gear after that and the pedal pressure went way up. Hope it's just the pressure plate.
#188
We've been using the Spec Stage 3+ with very good results. No problems with any of them yet that I know of. It has a much higher torque rating than the Spec Stage 3, and is a much smoother engaging clutch. Bob
#189
McLeod Single here... Been on for 1000+ miles. No problem. Very soft for a heavy clutch. It has almost a stock feel to it. I got the Kevlar/organic disc, so it engages NICELY. Very minimal chatter, only if you really try to ride it out. It seems to like to be engaged quicker.
#192
Originally Posted by SOMSS
After 2001 the LS1 clutch was the LS6 (ZO6) clutch. The new LS7 clutch is much stronger and just as smoothe as the OEM clutch.
#193
Originally Posted by LostCauseZ06
started with a spec stage 3 + had it go bad three times.
now i have a mcleod street twin... F****** love this little bastard. thing holds STRONG
#194
As we speek my full bolt on 02 WS6 is getting the t-rex and all supporting mods installed, lookin to do 3.90's and a clutch next, what do you guys recomend?
Keep in mind i live in a city, alot of stop and go driving, and i only street race for the most part.
#195
BMW ///M Nerd
Spec 3. Break in had a bit of chatter, not very much though.
Grabs hard now, after only breaking in for about 200 miles. No chatter,a nd I beat the bag out of it. I actually just grenaded my trans. last month.
I'll be pulling the spec 3 in favor of a twin disc Mcleod and aluminum flywheel when I get my Gforce T56.
Worked out well for me, but won't hold the power I intend to run next season.
#196
Originally Posted by sc68z28
A Mcleod street twin, 2 disc was in the car when this happened (thats a 9" Currie/Strange nod case)
---Bill.
---Bill.
Thats a testament to the grip of the clutch. It will find your weak link in the drivetrain. Although I wouldnt consider that to be a weak link!! How much power were you making?
#199
I have used centerforce dual friction. Not too cool. Centerforce uses a stock hub on thier clutches. They are really a stock clutch with metalic buttons on one side. The idea would work much better if they used a heavy duty hub like ram, hays, and I think Mcleod does. The stock hub has too fat springs that come into contact with the flywheel bolts on good aftermarket steel flywheels. I hope they are better for the f-body cars, but I have my doubts. It seems it would be better to use the ram 900 series disk with a light springed long style or b&b pressure plate with 3roller. If you really like the centerforce pedal feel and don't racing with a diaphram, get one of their pressure plates or just get the heavy duty Valeo plate since thats all centerforce uses anyway. I will be going with a Hays drag race 3 roller Borg and Beck and the ram 909 disk with my 32 lb ram steel flywheel when I reinstall my 350 next weekend. I will post what I think of this combo after my first night at the drags, which is where I place my importance on clutch performance.
Henry
55 Chevy
350 with cammel hump heads
3200 lbs
Muncie 4 speed
4.11 rear
M/T et streets
Henry
55 Chevy
3200 lbs
Muncie 4 speed
4.11 rear
M/T et streets
#200
Well, Stage 3+ here and no problems so far. (10,000 street miles with about 10 hard runs on street tires) I tossed the idea around for a long time and the shop that put mine in swore to me they've never had one they installed fail. Street driving it is fine unless you just can't stand a little extra work, all of those 10grand were in SoCal traffic. I'm the kinda guy that would daily drive a trex with open exhaust though so don't take my word for driveability.
