Problem with Cartek Clutch not disengaging??
Old 04-16-2002, 08:54 AM
MBC Racing's Avatar
LS1Tech 20 Year Member
Default Problem with Cartek Clutch not disengaging??
After my last trip to the track and a blown tranny, I was told by some guys with similiar problems that my clutch may not be disengaging all the way. I have the Cartek clutch and want to know if anyone else is going through this? What are some tips or advice?
I paid a LOT of $$$ for this thing and want to know what is happening.
Thanks
Brad
Old 04-16-2002, 04:48 PM
MIGHTYMOUSE's Avatar
Default Re: Problem with Cartek Clutch not disengaging??
put it in gear on a completely level surface, put clutch all the way in and rev the motor.. if the car creeps any at all, however slight, then ur clutch disk is still against the pressure plate. if it doesnt move, then move the pedal off of the floor until the car does creep forward.. it should be a noticeable amount.. or its not working right.
Old 04-17-2002, 08:58 AM
MBC Racing's Avatar
Thanks for the info. I will try it when I get the trans back.
